- eb145Explorer III have the Hughes Power Watchdog 50 Amp EPO (EMS) device and it works with my RV Whisper monitoring system so I can see all of the Power Watchdog data over the internet on my phone. I also get email and text message alerts when I lose shore power or the park wiring is bad. I have a dog that stays behind in the RV sometimes so I really like getting alerted whenever I lose shore power, even before the temperature starts to rise in my RV.
I also have the Progressive Industries 50 Amp hardwired EMS that I installed years ago, but of course it only displays the data inside the RV on the display.
So I actually have two different 50 Amp Surge Protectors (one on the pedestal, and one hard wired). Double protection, I guess. I really just wanted to get power alerts over the internet, and that only became available this year with RV Whisper and Power Watchdog. No sense uninstalling the hardwired Progressive Industries EMS. The Power Watchdog and Progressive Industries get along just fine. - sgfryeExplorer
dpgllg wrote:
Another vote for the Progressive Industries EMS system. Had mine for 2 years now and no problems
Dave
progressive vote here also. - wa8yxmExplorer IIIThere are two portables made by Progressive Industries.. The one I know the model of is the PT-50C If you read the specifications and what it protects against (Low and high voltage. among other things) the other one reads very much like it but is a bit lower in cost.. Either one of those would be my suggestion
My prefered is the HW-50C (hard wired) - DFordExplorerAbout 4 years ago I got a good deal on Camco's 50amp PD50. It's claimed to be water resistant. It was never submerged in water but it did hang from my MH while it was raining and it rained a lot last winter. When I connected it again, it started chattering after it's delayed startup. By then, I was on the other side of the MH involved with something else. I thought my neighbors were using a jig saw. When I figured out it was the protector and unplugged it, it's never worked again. I email Camco asking where to send it so it could be repaired. They told me there was no repair available and my investment in a surge protector was now worthless. I opened it up to find there was about a 1/2 cup of water in it that caused the problem. After it leaked in, there never was any sign of it being in there - couldn't leak out. I tried replacing the component that took the brunt of the damage with no luck.
That's my experience with the Camco product so I would recommend staying away from it. It only has a one year warranty and then it's worthless.
I started looking around and found the users of Progressive Industry's protectors saying they stood behind their products with a lifetime warranty. My next protector will be a Progressive product. - cougar28ExplorerIs the surge circuit on the Progressive Industries EMS replaceable or have to be sent back to Progressive Industries to be replaced?
- AllegroDNomadProgressive Industries EMS
- dpgllgExplorerAnother vote for the Progressive Industries EMS system. Had mine for 2 years now and no problems
Dave - fj12ryderExplorer IIIWe've got a Progressive PT50X which replaced a SurgeGuard 50amp. The first SurgeGuard stopped working about a week out of warranty, no obvious reason why. They replaced it under warranty after a bit of a conversation.
The one that replaced the first one failed due to water intrusion into the case about a year after it was out of warranty. It shorted out and damaged my 90° dogbone when it did, although we didn't know it at the time. The converter failed shortly after that so perhaps it was damaged too, no way to tell. But I would never buy another SurgeGuard, or recommend anyone buy one.
The Progressive unit works great and has been trouble free for the last year. - DutchmenSportExplorerWe currently have 2 different power protectors.
One is a Progressive Industries EMS-PT50X model. Progressive PT50X, click here.
I also have a "Power Watchdog" by Hughes Autoformers. It's a 30 amp. Click here for Hughes Power Watch Dog. "Watchdogs" also come in 50 amp models. Follow the links.
I purchased the 30 amp Power Watch Dog about 2 weeks before we traded our last travel trailer for our current 5er. The TT was 30 amp, and the new 5er was 50 amp. I decided to go ahead and keep the 30 amp for those times we might have to plug the 50 amp trailer into a 30 amp receptacle. (Which we did at first at home).
We used the 30 amp only once at a campground over the last year, we've been fortunate to have had all 50 amp site hook-ups, but I'm hanging onto the 30 amp Watchdog for those ... "Just in Case" events.
On my previous camper, the first protector I got was a 30 amp SurgeGuard. It was plugged in 24x365, non stop, unless on the actual road. It ran for one year and then died. I don't know if it took a power hit, or what, but it died. SurgeGuard would not replace it, and the thing was over $100 when we bought it. I then got a 30 amp portable Progressive for under $100. It worked OK until someone stole it. My third 30 amp was the Hughes Power Watchdog.
I have since purchased a bicycle cable lock I keep attached to the 50 amp Progressive. They aren't cheap by any means. So, I'm protecting my protector!
Meanwhile, I've had good results with my Progressive Industries.
Oh, since I'm sharing, I'll share one other thing I did in my last camper after the first Progressive Industries 30 amp was stolen. I removed the panel where the electric cord was stored so I could access it. I then cut the umbilical cord and put another plug on it. I then attached the opposite end plug back on the original umbilical cord. I now could plug in the power protector, in-line, but not exposed to the outside for theft. If anything ever happened, all I needed to do was plug in the original cord and I was back in business, or plug in another protector if it ever died. After this was set up, I never had issues again. I kept the protector when the trailer was sold, and simply plugged the umbilical cord back in. The new owner can get their own protector:
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
