DOTLDaddy's avatar
Aug 08, 2017
50amp shore power outlet to 15amp "side of house" receptacle
I am having my 30amp 5th wheel converted to 50amp service. I park my RV on the side of my house, where there is a 15amp household outlet less than 8 feet away. I have always plugged my 30amp cord into that outlet, using a 30 to 15amp adapter.
Here's the deal. My 30amp cord was of the old "pull it out of the little hatch" variety. I only had to pull the cord out slightly to hook it up to the 15amp outlet. No muss, no fuss.
The new 50amp service cord will be of the "twist-lock" type. Therefore, I would have to have the entire, 25 foot cord outside, laying on the ground, in order to use it with an 50/15amp adapter. I would rather not do that.
The ideal situation would be some sort of a short, 50amp twist-lock cord or adapter that I could plug into the nearby 15amp outlet. The long 50amp shore cord not being used at all.
Any ideas would be appreciated.
  • I would use the step down adapter and a custom made 15A extension cord.
    All the materials you need are available at a H/W store.
  • http://www.campingworld.com/shopping/item/50a-to-15a-rv-pigtail-adapter/72436
    Just order this 50 amp to 15 amp adapter
  • We bought a Camco 55582 adapter from walmart.Its the twist in 50 amp to 30 amp, bout 1 ft long. You could then use your 30 to 15 adapter.
  • You can't go wrong by putting a dedicated 50 amp receptacle for you trailer outside the house to hook into. I know you may not need the amperage provided but it will be much more convenient and safer. We use our rig when its parked in the yard and I don't regret putting mine in. Its really not all that expensive to do.
  • I have 50 amp also, tweety's.com had a twist lock 90 degree that connects to the camper, I think putting less stress on the connection, also they had a 50 amp to 115 twist lock to connect to that.
    Then all you need is a good extension cord.
    This is what I use however as you know you cannot power everything.
