nieforth's avatar
nieforth
50FT CAMCO HTD HOSE
50 FT CAMCO HEATED WATER HOSE. Hose plugged in power light on....should i feel any heat at all from the hose either along its run or at the connecting ends?
THANKS
  • On my Camco heated hose...you can run your hand anywhere along te hoe and feel the warmth.
  • We use a 25ft PIRIT heated hose, controlled by a built in t-stat. I have felt the hose from time to time and have never, ever noted it to feel even remotely warm to the touch. It does work very well though as we just went through some pretty chilly -18*C nights with no problems / frozen water lines.
    Cheers!
    Mike
  • I do not own one, but it should at least feel warm..unless it has a thermostat built in (my opinion)
    Our heaters for the stock tanks just warm the water and has a thermostat so they do not turn on until the water gets cold.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
