Skibane
Nov 24, 2021Explorer II
It really sounds like you were on the right track with cleaning the carb, but didn't go far enough.
Did you thoroughly clean the small passages? Typically, it takes a piece of small-diameter wire to rod them out.
Also, Sea Foam is not a particularly good substitute for carb cleaner.
