RV-1_2n-FUN's avatar
RV-1_2n-FUN
5500 Onan starts then dies, help please
2008 Onan 5500 that I neglected and did not run every month with load since May. Using start switch on the generator, first priming then start the gen. It starts and runs ONLY as long as I hold almost completely closed the butterfly under air filter. If I take pressure off the B-fly opens wide and sounds like gulping air then shuts down with code flashing 36. Reset code, prime and start up and again runs only by holding closed the butterfly. Sprayed plenty of Seafoam in to no avail.
Any ideas of problem???
TIA
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You sprayed seafoam into the throat of the Carb.
    But from your description I'd say it needs carb cleaned.
    it is SLIGHTLY possible that adding seafoam to the tank might help
    But I think Disassembly and cleaning is in order.
    NOTE: This is not the only possible issue.
  • Octane has absolutely no effect on the amount of crud building up in a fuel system.
  • Seafoam is a fuel treatment it doesn't work well after a problem exist. You gotta have in the tank and if your running lower octane fuels you'll get more **** built up in the carb.
  • A1B00902 wrote:
    check the oil level, Onan will not run if low on oil
    True, but holding the choke butterfly would not override the oil pressure LOPKO. Doug
  • dougrainer wrote:
    The seafoam did not work. You need to remove the carb fuel bowl and unscrew the needle jet assbly and clean out the 16 holes with regular carb spray. The carb is varnished/gummed up. Doug
    Will put your suggestion on today's "must do" list.
  • The seafoam did not work. You need to remove the carb fuel bowl and unscrew the needle jet assbly and clean out the 16 holes with regular carb spray. The carb is varnished/gummed up. Doug
Having RV issues? Connect with others who have been in your shoes.24,327 PostsLatest Activity: Oct 25, 2025
