fj12ryder
Jun 06, 2016Explorer III
You need to figure out if it's the motor, the gearbox, the cross shaft, or one or both of the leg gears.
Did the noise get better after the weight was off the legs? Either you need to isolate the problem or take it to a repair person. Repairing the legs may not be that bad, but you need to be able to get to all the parts. Replacing the legs completely isn't really that much more work, unless access is difficult.
I replaced the legs/gearbox/motor on my Fuzion with a dual motor design, with a motor on each leg. If you have a Venture system it's very likely underpowered for a large heavy fifth wheel.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
