What is the power cord going to the shop? Is it a 4 blade 50 amp cord or a 3 blade 30 amp cord? Are there any adapters or extensions on the cord?
When the 30 amp breaker trips does the main AC continue running? If so you are probably on 50 amps.
Without having any more information I can only hazard a guess.
If the 30 amp breaker is working fine with the portable AC unit running right up until there is a second significant load on the system. A load such as the water heater (on electric) coming on. Or the Microwave turning probably trips the breaker. If this is the case then you just need to be careful of your loads. Turn off or put the water heater on propane when you're running the portable AC. Temporarily turn off the portable AC to run the microwave. You can turn it back on once the microwave finishes.
Lack of water pressure can be many things. Are you running your water off the onboard fresh water tank and pump? Or are you hooked up to water from the shop?
If it's lack of pressure and flow out of the faucets try unscrewing the aerators out of the end of the faucet. With the aerator off you'll know immediately if it was plugged up and causing the problem. If you're on shop water try putting water in the fresh tank and run off the pump. Is there a difference?
I can only run both my air conditioners on SOME 30A circuits.
I am thinking of getting a portable AC but I would run a heavy extension cord to an extra receptacle - not through the RV panel. Of course, her husband's shop might not have another circuit available.
My 5er is 42' and it needs THREE ACs.
