TucsonJim
Jul 29, 2017Explorer II
Yes, Very lightly grind the bronze bushings until you take off just enough material to start them into the Equa-flex hole. Then use a press to push them in. The hole shrink when you press them. Use a 17/32" drill bit on a bench press to redrill them. Make sure you go slowly so you don't leave any rough edges. It works perfectly.
A second option is to replace the EquaFlex with MORryde CRE3000 or CRE4000 equalizers which will accept the bronze bushings just fine.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
