Bipeflier
Jul 30, 2017Explorer
TucsonJim wrote:
Yes, Very lightly grind the bronze bushings until you take off just enough material to start them into the Equa-flex hole. Then use a press to push them in. The hole shrink when you press them. Use a 17/32" drill bit on a bench press to redrill them. Make sure you go slowly so you don't leave any rough edges. It works perfectly.
A second option is to replace the EquaFlex with MORryde CRE3000 or CRE4000 equalizers which will accept the bronze bushings just fine.
Jim
That was what I figured out, wrong equalizers! Grinding down would be a chore as they are almost 0.030" too large in diameter. Drilling out the equalizers would be easier I think.
Thanks for the reply.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
