time2roll
Jun 20, 2014Nomad
If you are using 100 Ah per day you will need to run the generator 4 to 5 hours per day.
Start the Schumacher direct on the battery then plug in the RV. This may not be necessary but will prevent the portable from possibly getting confused. I would run the generator one hour after battery hits ~14.6 volts.
If the WFCO worked as expected it would cut the time in half.
If you are parked in the sun consider solar when the charging upgrade is considered.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
