pyrosecur's avatar
pyrosecur
6 volt battery post melted
Hi All !
Was caught in a snow storm coming back from Florida in March. Melting snow and ice caused a short and melted the positive battery post on the house battery. There were two red cables connected to this post, when I connect one of them everything works fine with the exception of generator starter. That is to say all 12 V appliances run normally off the house batteries. When I connect the 2nd red cable which was partially melted (with or without the first) it starts to smoke and melt again.
I have tried to follow this cable to find any obvious shorts but to no avail. Hopefully someone with more understanding in the community can give me some guidance ! I am kind of hoping someone will tell me of a solenoid or switch which may be causing the problem.
Thank You
Coach Info
Allegro Open Road 2004
32BA
Gas V10
  • If the generator would not start then that cable is more than likely for the generator starter motor. Do you have a volt/ohm meter?
  • Never encountered a melted battery post due to snow and ice. Can you post a picture or two?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
