RJsfishin wrote:
quote:
. If the batteries are very low to begin with, the charger will be putting out over 14 volts.
Not true.
Very low batteries could start as low as 12.8 to 13.2, at maximum amperage.
As the voltage comes up, the amps taper down. You will not see 14+ volts till batts are 70-80% ??
That's not accurate either, The voltage should jump up to the bulk rate within a few seconds. My PDI 9620 is at 14.X and 55 amps to the batteries after a deep discharge within 30 seconds.
I would suspect the battery is shorted if it wont allow 14V.
