67Tony's avatar
67Tony
6 volt battery problem
My two 6 volt batteries are brand new, and connected in series.
The TT was at the dealer for warranty work, for about a month. When I picked it up and tested the batteries they were at about 30%, despite being 100% when I dropped it off.
I was a little miffed, but came home and hooked up to 110 from my garage, thinking that over several days the onboard inverter would boost me back up.
Much to my dismay, after two days hooked up, the batteries still read about 30%. I now have them isolated and connected to a smart charger, which has been feeding them 25.8 amps for several hours.
Why were these batteries not charged up by the onboard inverter/charger? I know that dropping them down to 30% is not ideal, but it shouldn't wreck them, should it?
  • Check the fluid level in the batteries. If they're quite low on water they won't take a charge. Also feel the sides of the cases to be sure they're not oveheating thus off-gassing. This would be the result of an internal short most likely. There is nothing about discharging them 70% that SHOULD cause them to fail completely though it's never a good idea to do this often. A good set of 6 volt batteries should easily recover from even a deep discharge. The REASON they were discharged when you picked up the RV was that it was likely not connected to 120 volt AC power while at the dealers. I've never had a dealer hook mine up while they have the trailer. I just disconnect the negative lead when I drop it off, put a note on the door telling them that the batteries are isolated and they hook them up if/when they need to. Otherwise they are returned nearly fully charged.
  • quote:
    . If the batteries are very low to begin with, the charger will be putting out over 14 volts.
    Not true.
    Very low batteries could start as low as 12.8 to 13.2, at maximum amperage.
    As the voltage comes up, the amps taper down. You will not see 14+ volts till batts are 70-80% ??
  • 30% of 12.6 volts is approximately 3.78 volts. Is this what you are measuring?
    In any case, you're correct in assuming your on-board charger should have kept the batteries at a full charge or better...typically a float to absorb charge is 13.2 to 13.6. So, it seems either you have the batteries disconnected from the system, or your charger isn't working properly.
    With the TT plugged into shore power, what is the voltage measurement on the batteries? If Charger is working, you will not measure less than 13.2 volts. If the batteries are very low to begin with, the charger will be putting out over 14 volts.
    Make sure your battery disconnect switch is in the on position. Measure and let us know what you find.
    Ron
  • RoyB's avatar
    RoyB
    Explorer III
    Hate to say it but from past experience of what others have reported it probably has done your batteries in. You may be able to get them back again but they will most likely not be at the same new performance before they was discharged below the 50% charge state.
    I have never returned any of my trailers back for warranty work but if I did I would most definitely remove my large expensive battery bank and let them deal without a 12VDC battery source. I might connect up a Lawn Mower 12VDC battery to get me to the dealership and be legal with DOT safety regulations.
    We have alot of money invested in our battery banks and you know the dealership is not going to replace them if they were discharged during the time the trailers set in their shop.
    Just my thoughts here
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
