BFL13
Jun 16, 2014Explorer II
Bcbickford35 wrote:
I have 2005 keystone TT I currently have 2 12 volt batteries that are shot. I have enough space for 3 batteries. About half our camping is boondocking. Am I better off replacing with 2 6 volt batteries, or 2 6 volt and 1 12 volt, or just replacing the 2 12 volt. Your advice is much appreciated
Two 6s are way easier to charge up and they can take more really deep cycles than 12s can.
You don't say what your daily AH usage is, so there is no way to know if two 6s at 232AH is plenty, or if you do need to go higher. If you do need more AH to support your daily usage, then you are stuck with the three 12s option since you can't have three 6s. You can have two 6s and a 12 but that gets very hands-on to keep going properly, which you may not be "into."
You can get 300AH with two T-1275s but I don't know the price comparison with three 29s. The T-1275s are true deep cycle, not hybrids like the 29s.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
