BFL13
Jun 23, 2014Explorer II
Have to run a capacity test on them each way, but how do you know the 20hr rate to use for the ten hour run down to 50% if you don't already have an idea what the capacity is? You know you are at 50 by SG and voltage (after voltage bounce back for an hour)
BTW Phil, it says in that Trojan guide mena linked that using a resistance test method for measuring capacity on a deep cycle batt is bad for it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
