Huntindog
Jun 23, 2014Explorer
RJsfishin wrote:They won't accept a charge at the same rate. The two sixes would be able to accept a higher charge rate, but they can't because the lone six will be the bottleneck. So yes they will charge equally, but at the slower rate. They will all end up at a full charge.
I never could see why the 3 6'ers wouldn't work, but the hi tech'ers on this forum wouldn't have no part of it.
Maybe look at it in a reverse flow fashion,......if you were charging the 3 6'ers, dare tell me they wouldn't charge equally. So if they'd charge equally, they'd discharge equally !
When discharging, the lone six will again be the limiting factor. When it is discharged, the two sixes will still have plenty left.... I suppose by rewiring them as normal, that you could then have a few more amps available. But then would need to rewire them again to charge. Sounds like a hassle for little gain.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
