wwest
Jun 23, 2014Explorer
RJsfishin wrote:
I never could see why the 3 6'ers wouldn't work, but the hi tech'ers on this forum wouldn't have no part of it.
Maybe look at it in a reverse flow fashion,......if you were charging the 3 6'ers, dare tell me they wouldn't charge equally. So if they'd charge equally, they'd discharge equally !
Simple, when the single 6 volt battery reaches a state of full charge the 2 6 volt parallel batteries have each only reached 1/2 of the charge "power" that the single battery received.
50 amp charge current, only 25 amps for each of the parallel batteries.
Worse yet, in order for the total fully charged level terminal voltage to reach the nominal 12.8 volts the single battery will be being overcharged and seriously outgassing.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
