MEXICOWANDERER
Jul 27, 2017Explorer
ktmrfs
"A pair of GC batteries will drive a 1000W inverter untill the battery is down to around 80 percent SOC, then the inverter will alarm and shut down due to low input voltage. Now that means unless a pair is well charged, you may be out of luck even at 1000W"
Cannot this trait be deemed and treated as a "STUPID PREVENTER"?
Very very few RVs have the battery capacity to run a thousand watts long-term. And usually if high wattage is desired for an extended time I have a very hard time arriving at a justifiable reason. That's right up generator use alley.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
