MEXICOWANDERER
Jul 28, 2017Explorer
And yet...
A clinical specific analysis of wet GC vs AGM case-by-case may tilt the factor in favor of AGM. This is where an RV owner needs to use the stuff between the ears. Everything is a compromise. And everything can be biased with quantification.
I remember the shock on the owner's face when I recommended (4) 1105 Delco calcium calcium flooded (sealed) engine starting batteries for his dedicated inverter battery system. 950 CCA x (4) It was far too long a run from his L-16 bank to the inverter. An MCI conversion bus. 24 volt.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
