pnichols
Jul 30, 2017Explorer II
MEXICOWANDERER wrote:
Oooooo and dat's the rub.
There are no group 24 and group 27 batteries that have the .070" plate thickness of the most puny GC220.
Or any of the AGM batteries having anywhere near the plate thickness of the Lifeline.
Or larger batteries having .330" plate thickness of my Rolls cells.
David ... be careful about the Lifeline plate thickness as being the head-and-shoulders champion. Note that we do not know the thickness of the plates in my Fullriver AGM Group 31 115 AH batteries, which weigh a little over 72 lbs. each ... while the 130 AH AGM Group 31 Lifeline batteries weigh arouund 75 lbs. each. Which means that the amp-hours per unit of lead volume of the two brand names is VERY CLOSE. Dividing 115 by 72 equals about 1.60 amp-hours per lb. for the Fullrivers, while dividing 130 by 75 equals 1.73 amp-hours per lb. for the Lifelines.
The Lifeline does indeed win (very) slightly in energy storage per volume unit of lead ... but certain potential buyers of the two brands would have to be able to tolerate the two down-sides of the Lifelines over the particular Fullrivers I'm comparing them to before going with the Lifelines. All this means that plate thickness of the two brand names is very close to the same - since both battery brands are of about the same Group 31 dimensions.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
