MEXICOWANDERER
Jul 31, 2017Explorer
The EXACT positive plate thickness is a manufacturer specification. When I examined that battery I found clues not hard data. My 2013 finding provided compelling clues. Your bumped response above is what prompted me to pursue the data. I am loathe to present clues as being hard data.
Believe what you wish :)
You can do your own clue uncovering.
Perform a BCI recognized CCA test on the two samples. 50% of OEM rated CCA in amperes discharging for 15 seconds.
Perform an impedance test on both units.
A CCA test performed on my light 31 revealed a CCA rating of 630 amperes which was conducted at a temperature of around 65F
An inversion of an impedance test was the Lifeline battery accepts 103 amperes at 14.4 volts.
Is not the ultimate goal to have a product satisfy your own demands? If it works for you that's great. My great limitation is I cannot warranty a 30 day or 30 year battery. That heavily skews my product performance demands. From light bulbs to clothes to appliances that are not available down here, I have to stick with stuff that stays working. I wish it was otherwise.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
