mike-s
Aug 14, 2017Explorer II
OldSmokey wrote:If you think that's how it's done, you're doing it wrong.
for this example your batteries numbered 1,2 and 3 are connected in parallel string with the take off on battery 1 to your equipment.
Wrong (both external connections to the same battery. Consider the pairs to be single batteries, this is just the clearest drawing easily found):
Right (external connections at opposite ends, so there's an identical voltage drop to each battery):
you now discharge at 90 Amps. you would think that each battery will supply 30 amps right ?.. well your wrong,Wrong only if the wiring is wrong.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
