OldSmokey
Aug 14, 2017Explorer
for this example your batteries numbered 1,2 and 3 are connected in parallel string with the take off on battery 1 to your equipment.If you think that's how it's done, you're doing it wrong
I KNOW that's the incorrect way, I was highlighting that method for the OP's education.
Wrong only if the wiring is wrong.
you now discharge at 90 Amps. you would think that each battery will supply 30 amps right ?.. well your wrong,
you will be surprised to learn that even if they are connected as you post, the batteries will still be imbalanced ( to a lesser degree ) due to the internal resistance and capacity.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
