Hello, I have a 7.5DKDFJ Onan diesel generator that starts and runs, powers the inverter/charger. The problem I’m having is when running the roof air, it runs the fan fine, but when the compressor kic...
Don't know if you solved your problem, as reply is a bit dated. 7.5. DKD with low volts probably voltage reg, (most DKD's use a transformer type regulator)make sure engine running at correct speed (1800rpm= 60hz on this gen). Low speed will have low voltage output. Other possible causes are partially shorted exciter/rotor/stator winding
