BFL13
Jul 22, 2014Explorer II
I got the connection corrosion problem in the truck's end where the Chev version comes in two parts for some reason.
The corrosion was hidden between the two halves and not at the pins end you can see, which were ok. Had to take it all apart. That led to more fun where Chev wire colours don't match the 'standard' 7-pin colours plus you have the mirror image problem with the two halves.
Sort of an IQ test which I was mostly failing. Got fed up and replaced the Chev thing with a standard one piece 7-pin connector :) That, I am able to understand!
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
