ScottG
Nov 14, 2017Nomad
Normally, there are no relays involved in the 7 pin. You could just wire the 7 pin's cable to the circuits it's supposed to go to and skip the relays.
Prev owner probably had something special wired up. In my own case, I had the running lights being powered by the charge wire and just used the running light circuit to energize a relay. That kept the load on my trucks lighting circuit to a bare minimum.
EDIT, after reading Enblethens great post, that may indeed be what it is.
If there are only two connection point on these devices, then they are not relays.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
