SoundGuy
Nov 14, 2017Explorer
mikakuja wrote:
Does anyone have any knowledge of how these relays should be wired, or even pics of your current wiring may be able to help us to figure out how to re wire the relays.
Can't imagine why there'd be any relays but here are the Bargman 7-pin pinouts. Wire colour codes indicated are common but you'd want to confirm each circuit though, particularly if someone has been in there before you and may have changed something.
Self resetting circuit breakers make more sense and if there are two one would be protecting the main + 12vdc line feeding the trailer, the other most likely protecting a slide motor.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
