ktmrfs
Mar 26, 2017Explorer III
I think you've discovered how the inexpensive LED lights work. they use a dropping resistor to the LED BAD BAD BAD BAD design. Why? well, LED's are a constant CURRENT device, not constant voltage. Increase the voltage and you increase the current, which increases the power draw, which increases the temperature which decreases the LED junction drop, which increases current. Get the picture. Now bump the voltage to 14.8V or more agrivates the problem tremendously. Either they are dim at 12V or have premature life at 14.6V.
Good designs use a pulsed constant current design that has RFI suppression. not cheap, but much longer lasting.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
