DiskDoctr
Mar 26, 2017Explorer
Can I use this relay to switch the DC lines?
It is AC/AC 80amp rated.
I know that a contact is blind to AC vs DC, but SSRs also have some odd behaviors, so I'm asking ;)
If so, is it enough amps for the DC line to power the CAMPER, not the battery charging? The existing 8955an is 950watts input/55amps output, including batteries.
Thanks.
HQ 80A Solid State Relay SSR AC-AC Input 70-280V AC Load 240-480V ?AC A4880
Condition: Brand new
Load Current: 80A
Load Voltage: 240-480V ?AC
Control Voltage: 70-280V AC
Control Current: AC ? 12mA
On-off Time: ?10mS
Dielectric Strength: 2500VAC
Insulation Resistance : 1000M ohm/500VDC
Ambient Temperature.: -30??75?
Working indicators: LED
Size: 58 x 45 x 32mm
Certification: CE
Qty: 1 x Relay
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
