BFL13
Mar 26, 2017Explorer II
I don't understand the concern with lights and 14.8v.
The entire time you are on shore power you will be at 13.6v. The entire time you will be off- grid you will be at 12.x volts. Except for a couple hours every so often when doing battery charging.
Mostly? you will do your battery charging during the daytime, so you don't need to turn on any lights for the couple hours that takes.
What is the scenario for having the LEDs on when your 12v system is at 14.8 ?????
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
