DiskDoctr's avatar
DiskDoctr
70 amp charger cooking 12v LEDs?
Will using one of the upgraded 70amp Progressive Dynamics charger/converters fry my new 12v LEDs (unregulated version)?
I've seen talk of leaving the old converter in place, deck mounting the new one close to the battery, etc, but don't these interfere with each other?
Do you turn the original one off?
The new converters are 14.8v, will that hurt the LEDs?
The LEDs I ordered to upgrade out new-to-us camper are superb color and light, same model and seller as our hybrid, but they only come non-regulated.
Is there any wisdom to adding a large inline voltage regulator between the new battery and the distribution panel to protect LEDs, slide motors, etc?
Then run a second heavier set of wires from the PDC to the battery?
That would send 14.8v from the PD to the battery for charging, but the battery to distribution panel leg would only be connected through the existing, single "charging/power" wires THROUGH a new voltage regulator.
It seems to me this is how a good system *should* be designed anyways?
I asked some similar questions in a different section, but didn't get these answers. I should have posted in this section.
I am looking to upgrade our 8955 to PD 9270C
70 Amp RV Converter/Charger
The PD9270C-14.8, 70-amp power converter is designed to provide reliable filtered DC power for batteries that require a higher boost/bulk voltage such as Trojan and others. The PD9270C-14.8 converter also provides safe and rapid recharging of RV batteries. Built-in features such as electronic current limiting, reverse battery protection, high voltage protection, low voltage operation, and over temperature shut down ensure long-term reliability. The built-in Charge Wizard is a microprocessor-controlled system that constantly monitors the battery voltage and ensures a rapid; yet, safe, recharge. The Charge Wizard can select one of three charging voltages and one of four operating modes depending on the condition and use of the battery.
Features:
Built-in Charge Wizard
Reverse Battery Protection
Delivers filtered DC power to all 12 Volt lighting and appliance circuits, providing safe and reliable service
Electronic Current Limiting
Low line Voltage Protection
Variable speed intelligent Cooling Fan
High Voltage Protection
Automatic thermal shutdown
Built-in accessory port for the Converter Status Remote Pendant
2 year limited warranty
Input: 105-130 VAC, 1250 Watts
Output: 13.6 VDC, 70 Amps
Dimensions: 3.6" X 8 X 9
Weight: 5.8 lbs.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
