ScottG's avatar
ScottG
Nomad
Nov 19, 2023
Solved
80 amp converter and eu2000i
I'm putting together a 400A Lipo4 battery setup (4x100) and would like to charge it with a Progressive Dynamics PD9180AL converter, which I would occasionally run from my Honda eu2000i (1600W continu...
  • road-runner's avatar
    Nov 19, 2023
    Other than in advertising, the portable generators are rated in volt-amps (VA), not watts.  As you noted, with the power factor less than 1.0, the converter's draw in VA is higher than it's draw in watts.  In practical terms, the generator output is lower than the advertising wants you to think, and the converter's draw is higher.  My old PD9160A pulled 1,386 VA when providing a full load output of 864 watts.  Interpolating the numbers from 60 to 80 amp output yields 1,848 VA needed from the generator, above the eu2000i's continuous rating, and its maximum output if you're much above sea level.  Those numbers should be valid unless PD has improved its efficiency or PF over the years.  At the full power load, the 9160A's draw in watts was 952, so from interpolation, 1,300 watts for the PD9180AL is right on.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
