Almot's avatar
Almot
Explorer III
Feb 09, 2014
80VDC 10A fuse?
Thinking of arranging my solar setup "the right way" - add all the recommended fuses, like PV fuse, battery fuse, controller fuse and load fuse. It works as it is, so I'm going against the rule "it works - don't fix it" :)
Suddenly discovered that there are no fuses rated over 32VDC, at least within reasonable price. My array has 60 Vmp, 8.1 Imp. So I need a fuse rated 80VDC 10A (or 15A?), and don't see any. Breakers - yes, but not fuses.
I have already decided (99%) in favor of set of breakers and a box like Baby Box or Big Baby, from Midnite Solar. This would take care of 80VDC fuse as well, and easier to switch off any components than with blade fuses. It will also have a room for Pos and Neg buses, everything in the same enclosure. But maybe I'm missing something?
Oh yeah, and the battery fuse will be a separate fuse from Blue Sea, screwed right on the terminal where it belongs, so it's not really "all in the same enclosure" - just didn't want to dilute the topic. The question is mostly about 80 VDC PV fuse.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
