BFL13
Oct 18, 2021Explorer II
8531-11/111 mix (parts swapped here and there) has actual flame sensor, not the new two prong method like a 1V has.
Battery voltage start- 12.59
Battery voltage furnace running- 12.50
Voltage at furnace CB- 11.34
Voltage at thing to the right-10.93
Burner cuts in and out fairly often. Burner screen, sparker, orifice all clean. Manual suggests flame sensor voltage bad ground or too low?
Sparker and flame sensor is above the burner screen quite high, can't bend the three prongs down closer, but the two prong type as seen on a youtube is supposed to be closer to the screen than mine is.
Don't have voltage for the flame sensor after that 10.93, but could be lower than that?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
