BFL13
Oct 18, 2021Explorer II
Could be the control board--I did just clean the edge contacts so have to try that first when I put this thing back together.
Found the other metal part in my spares box--it has the white gasket in better shape than the one in use. Now I don't know if the gasket should be better or keep using the one there now. What is it for?
Ok, do the screws make a ground contact between the two pieces of metal so the idea is to clean where the underside of the screw tops touch the plate? (And the underside of the screw tops as needed.)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
