MT_BOB
Oct 18, 2021Explorer II
Yes it is a gasket,it is sold separately-- 32172
You have 1 probe,1 igniter, and 1 ground for the igniter. All 3 should be closer to the burner. What you do to bend them is use 2 pair of pliers,go further up the "shafts", hold with 1 pliers and bend with other. Keep the distance the same between the igniter and it's ground. Do not bend by just pushing on them,you can break the ceramic insulator they are mounted in.
As far as other issues,you also may have the snap switch going bad, they can do strange things,
and,I believe your voltage differential is not good.
(it matters not where you bend them)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
