BFL13's avatar
BFL13
Explorer II
Oct 18, 2021
8531 /Burner Issue UPDATE--Photos ( Fixed!)
With the furnace running, where do you put the pos and neg leads of the meter? Or can you do it at the Tstat inside with the furnace on?
I want the 12v to the board, not the voltages the board puts out to the various components. eg,I got 10.67 at the gizmo on the right of the fan casing and some metal nearby, but I don't know if that is the loaded 12v with the furnace running or what.
Thanks
  • Good job,and good luck. Usually those terminals are crimped and spot welded,I do not think solder would be something to try.
