BFL13's avatar
BFL13
Explorer II
Aug 05, 2020
8531 Furnace Duct Adapter Install Questions
https://www.amazon.com/Hydro-Flame-Corp-31474-Adapter/dp/B00CLSWS6I
I have an 8531 furnace with 4" knockouts for the ducts. The duct adapter is listed as 1474 in the manual, but get this on Amazon which seems to be the right part. I want to add a duct.
1. How do you get it in/on and to stay there after you knock out the knockout?
2. Do regular hardware stores sell these instead of using the Atwood part?
Thanks
EDIT--found this way down in the link above--not clear how it goes in the hole in the first place. " a 1/4 turn"
  • subcamper wrote:
    I have added lots of these to my home HVAC system.
    You can buy them at Home Depot, Lowes, etc. Just find one that fits the hole/duct size.
    Usually they have a bunch of fingers that you reach through the hole and bend over against the inside of the plenum to hold it in place.
    Steve
    Great! Thanks to both replies. I understand it now.
  • I have added lots of these to my home HVAC system.
    Steve
  • If you look closer there is a 'split' in flange that goes between furnace frame so after you remove knockout you slip it in and twist
    Duct goes ON the stub and is held inplace via clamp
