paulgg
May 30, 2015Explorer
The fan is working again. Thanks to all that offered suggestions. It was not a fuse or switch. I took apart the 12V ceiling light closest to the fan to see if there was any power coming into the fixture. This light was not working either. I found a crimp-on barrel connector where the wire had pulled out. I measured 12V on the loose wire. When I re-connected it, both the fan and the light came back to life.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
