Dannyhawk101
Apr 07, 2015Explorer
Ok... DREW E. well here I am in April but the situation has been identified finally after a couple of months of not having a Generator and fretting over the replacement cost and Chassis retrofit for a newer Model. As it turns out after replacing everything possible that could blow a fuse in the Control Box ( namely, Temp sensor switch, Oil sensor switch, Fuel Solenoid, Fuel Pump, Control Board ouch 400.00 just for that but at least I got a spare :), I mean I went back to Cummins here in Miami at least 6 times for "the" part that I knew would solve the problem. It got to the point where the Cummins Parts Sales guy said why don't you just give up and bring it in Man!. Of course I couldn't do that because they at 100.00 bucks an hour would have certainly put me in the Poor House trying to figure this one out. As it turns out the problem was a "Crumby" 12v lead off the Fuel Solenoid back to the Fan! But I did not know where that particular lead went to at first. So by sheer Dumb Luck out of Frustration I happen to try disconnecting some leads, then starting and re-starting over and over... That particular lead has a 20 Amp in-line fuse attached (must have checked that fuse 100X),,,,I hit the start switch and to my amazement the Genny kept running!. Scratched my head, Shut her down again reconnected the lead and tried again and the fuel solenoid disengages and she shuts down! So hoping that lead meant nothing to the Genny operation...lol.. I left the lead disconnected to run the Genny and she ran perfectly while I'm underway. But first time I stopped for a longer period she began to overheat. That's how I discovered it was the lead for the electric cooling fan that sits in front of the Radiator! The electrical wiring diagram for the generator doesn't even show a Fan lead! The Fan works fine albeit when the lead is connected. So now I simply remove the lead to the Fan in order to start the Genny and then reconnect after starting so the Fan runs! Apparently the electrical draw of the Fan upon start-up was enough to trip that DC Breaker in the Control Box! I HOPE THIS SAVES SOMEONE ALOT OF TIME , ENERGY AND MONEY... AND I MEAN ALOT OF TROUBLESHOOTING ON A PROBLEM THAT EVEN STUMPED THE GENSET EXPERTS HERE IN FL. AS WELL! CAME DOWN TO INSANE FRUSTRATION WHERE I JUST STARTED PULLING WIRES OFF AND STARTING AND RE-STARTING OVER AND OVER... LOL.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
