rayroof10's avatar
rayroof10
95 fleetwood furnace
Hello again, my furnace is a atwood 8500. the hydro flame will come on but the furnace would,nt lite. so l tapped on the valve and it fired up. after 3-5 minutes the furnace cut off, after a little while the hydro flame came back on but furnace would not lite again, tapped on valve again but nothing. didnt want to keep on tapping on valve in case it was something major. Thanks.
  • Yes, it could be a dirty sail switch and by tapping on the gas valve it may move enough to close the contacts.
    Another thing is to look at the gas valve. Most have two coils that both need to operate the gas valve. Locate the four wires going to the valve. Should be two wires connected together going to ground and two wires connected together going to the circuit board. disconnect a set of wires and check the coils for continuity. Each coil should be very close to being the same resistance.
    The furnace may need a good cleaning. Blowing out with compressed air will do wonders for getting dust and other debris.
  • my camper is a travel trailer, 35 ft Fleetwood prowler, with the Atwood 8500 furnace.
  • If tapping the gas valve causes it to come on, that suggests a bad valve.
    BUT, start with the basics. If the furnace fan runs, but the furnace does not light (gas valve open AND igniter click), the SAIL SWITCH may not be closing. Causes of this: low voltage (measure at the furnace) causing fan to turn too slowly. Restriction in air return and/or vents and ducts causing reduced air flow. Or, the sail switch may be bad (least likely).
    Quick check-- start engine and hold at high idle so voltage is up. Any different symptoms?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
