BFL13
Feb 11, 2017Explorer II
There will be a pause in the program--- a plastic part (hate that!) in the recoil starter pull gizmo broke off. Am going to try it glued on, but not expecting it to hold. Probably have to get the part to get the gen started and check the three-light tester etc.
EDIT yep all repair efforts failed including a sheet metal brace with pop rivets. I ordered from eBay, due in a month or so. Might get lucky downtown next week at various repair shops though. Troy does their warranty work locally, so try there first.
http://www.kingcanada.com/Files/KCG-951G_service_manual.pdf
It is the Drive Pawl--#100
I will only be running the Vector portable charger with it, never the rig itself via the shore power cord, if that matters for grounding it or bonding etc. I have tried that much already and it all works to recharge the batteries.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
