SoundGuy
Feb 22, 2017Explorer
BFL13 wrote:
One question from before was about grounding and bonding so stick the three- light tester in it. Did that just now---shows two yellow lights "normal" unlike my Honda inverter-gen which has a floating neutral. One of the yellows was flickering a little if that means anything. (same yellow that indicates open neutral when only that yellow is showing)
Why not blow the budget like the big boys and spend a whopping $20 on a DVM that will tell you far more than any flickering light tester. :h :W
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
