westend
Feb 23, 2017Explorer
BFL13 wrote:Is it possible to rotate the recoil and install it so the pull cord exits the recoil towards the top?
Biggest problem now is starting it, which pulls the gen towards you instead of pulling the cord out. It is also for right-handers who can use their left to hold the gen while pulling the cord mounted on the right side of the gen. Even then you need to get on your knees down level with the gen on the ground. If you pull with your left, you can't reach over with your right to brace the gen properly. I need a way to anchor the gen while pulling on the starter cord. Tie it to a tree or something.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
