BFL13
Feb 23, 2017Explorer II
No the recoil starter has four bolts that go a certain way.
http://www.ebay.ca/itm/Gas-Generator-Recoil-Starter-For-ETQ950-TG1200-63CC-1000-1200-Watts-Pull-Start/291639192070?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140620091118%26meid%3Dafa69fd4e2874def9d4fb4ca328a4322%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D272524525594
I tried that carb prime method of getting started and I still flooded the thing. Have to remove spark plug and pull a few times to air it out (and wipe off the plug) like it says in the manual--replace plug and pull a few times and then it fires right up. 40F out. I hope this will get better when the SeaFoam is all used up in there.
I know about starting the gen first then add the load and VV, but this problem of running out of gas so it stops with the load still going is a new one on me. Also they say if you slightly overload the watts rating it might not pop the circuit breaker but it can add wear to the generator. I don't know from my K a W tests with the Vector if it was pushing the envelope that way or not. ( It ran the Vector ok and the gen sounded like it was running well, but the gen's output voltage fell to 99v remember)
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
