MrWizard
Feb 26, 2017Moderator
BLF
if you can't hold it with your left and pull with your right hand to start
then consider turning the generator around, just put a hole & gromment in the back side of the pulley cover for the rope
so you can pull with your left hand, with the genny turned around
the rope only winds around one way, the engine only spins one way
you just end up with the rope pulling up from the bottom instead of the top when you turn the genny around
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
