allegrobus2002's avatar
May 19, 2018
A & E one step power awning motor
We have had problems with the A & E power awning -- it will extend just fine but getting it to come back in is another issue. It will begin coming in but very very slowly for a while, then it eventually takes off and comes in at normal speed, usually. sometimes, my husband taps on the motor with a mallet to get it going. He and his buddy have had the motor apart and cleaned and oiled it but we are back to the same problem. Is there a spring or something on the other end of the awning tube that could be rusted, sticking. It acts as though it was sticking for a while and finally overcomes that. Any help will be appreciated.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to "member" issues with Open Roads Forum sites. Signatures, profiles, photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
1 Reply
  • Are you sure it isn't wound in the opposite direction? That is the symptom of having done so.
    In other words, if you hold the extend button too long it will begin rolling back up in the wrong direction.
