kerrlakeRoo
Mar 17, 2018Explorer
A heavy duty extension rated at 15 amps, with an adapter for your 30 amp connection is what you need. It will handle lights and the converter as well as the resi frige. Trying to run the AC at the same time likely won't work.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
