ppine
Mar 18, 2018Explorer III
Most garage circuits are 20 amps (12 gauge wire). Park your rig close to the hosue if you can to recharge and use a short extension cord to reduce voltage drop. Turn off everything you can to reduce the load. You can charge your batteries and run your refer at the same time with 20 amps on a 30 amp trailer.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
