Boon_Docker
Dec 09, 2021Explorer III
ajriding wrote:
Trees and plants LOVE CO2 !!!! More CO2 means more green plants. The world is greener than ever.
If you want to know for yourself how much we are lied to then you can do an easy experiment yourself right in your kitchen.
Take a bowl and put a big chunk of ice in it. Maybe freeze a paper cup of water and use that as the chunk. put the ice in the bowl of water and mark precisely where the water level is. Let the ice melt. Now mark where the ice level is. You will realize how big the lie is.
Hint, the water level does not change when the ice melts.
One pound of ice is one pound of water.
One pound of ice displaces the EXACT, precisely the EXACT, same amount of water as one pound of water.
Sea ice, which by definition is ice on the ocean, when melted, will not increase ocean levels one bit, zero, nada, ziltch. This is the big lie people fall for over and over and over. It is such simple science, but so many people fall for the simplest of lies.
If all the sea ice on earth melted NOTHING would happen to the ocean levels. They would remain the exact same as they are now. Your vacation house built 3 feet above sea level would still be 3 feet above sea level if all the ice melted.
There is not enough fresh snow/ice on land to do much of anything to sea levels either. Almost all the ice is floating on the ocean.
The Arctic Sea ice is increasing in size currently. Sea levels are not lowering.
Sea ice does not cause water level to rise, polar ice sheets (on land) will increase the sea level when they melt.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
